Joomla 5 Mitteilung
Radio Button and conditional fields doesn't work
2 Wochen 4 Tage her #10388 von naderfarid
Radio Button and conditional fields doesn't work wurde erstellt von naderfarid
Hello.
I have an urgent problem that I couldn't find in the forum.In the link below, there are two conditional fields, none of which work properly, and if one of the radios is selected, the other option will be disabled, and then the user must refresh the page again. The second problem is that only one of the options worksI use Joomla 5 and your latest version, 4.4.2I request that you investigate this case.
tigerseyekaratedo.com/index.php/free-trial
2 Wochen 3 Tage her #10389 von Administrator IV
Administrator IV antwortete auf Radio Button and conditional fields doesn't work
Hello naderfarid,
I examined and debugged your site using the web browser developer tools.
Use the following values for the radio box options:
-> 291 Pemberton Ave, North Vancouver
-> 181 Roundhouse Mews, Vancouver
If you remove the combination ', ' from the values then it works.
The combination ', ' (comma plus space) cannot be included in the values of the options.
However, this combination is not a problem in the visible label of an option.
This fact is not yet pointed out in the documentation.
We see this as a deficiency in the Visforms documentation and will expand it to include your point.
I have created an issue to expand the documentation:
Issue [VF-1100] Forum: Docu: Conditional Fields: Add important note: Avoid character combination ', ' (comma plus blank) in option values
If we have expanded the documentation, you will be explicitly informed about this here in the topic.
Kind regards, Ingmar
Folgende Benutzer bedankten sich: naderfarid
2 Wochen 3 Tage her - 2 Wochen 3 Tage her #10391 von Administrator IV
Hello naderfarid,
the issue [VF-1100] from above has been implemented.
The documentation has been changed accordingly.
A warning has been added to the following section.
The configuration:
docs.joomla-5.visforms.vi-solutions.de/e...s/#the-configuration
Letzte Änderung: 2 Wochen 3 Tage her von Administrator IV.
