Joomla 5 Notice
Radio Button and conditional fields doesn't work
3 weeks 20 hours ago #10388 by naderfarid
Hello.
I have an urgent problem that I couldn't find in the forum.In the link below, there are two conditional fields, none of which work properly, and if one of the radios is selected, the other option will be disabled, and then the user must refresh the page again. The second problem is that only one of the options worksI use Joomla 5 and your latest version, 4.4.2I request that you investigate this case.
tigerseyekaratedo.com/index.php/free-trial
2 weeks 6 days ago #10389 by Administrator IV
Replied by Administrator IV on topic Radio Button and conditional fields doesn't work
Hello naderfarid,
I examined and debugged your site using the web browser developer tools.
Use the following values for the radio box options:
-> 291 Pemberton Ave, North Vancouver
-> 181 Roundhouse Mews, Vancouver
If you remove the combination ', ' from the values then it works.
The combination ', ' (comma plus space) cannot be included in the values of the options.
However, this combination is not a problem in the visible label of an option.
This fact is not yet pointed out in the documentation.
We see this as a deficiency in the Visforms documentation and will expand it to include your point.
I have created an issue to expand the documentation:
Issue [VF-1100] Forum: Docu: Conditional Fields: Add important note: Avoid character combination ', ' (comma plus blank) in option values
If we have expanded the documentation, you will be explicitly informed about this here in the topic.
Kind regards, Ingmar
The following user(s) said Thank You: naderfarid
2 weeks 6 days ago - 2 weeks 6 days ago #10391 by Administrator IV
Hello naderfarid,
the issue [VF-1100] from above has been implemented.
The documentation has been changed accordingly.
A warning has been added to the following section.
The configuration:
docs.joomla-5.visforms.vi-solutions.de/e...s/#the-configuration
Last edit: 2 weeks 6 days ago by Administrator IV.
