Publish Carousel inside an Article
You can publish a carousel inside an article by using the Joomla! content plugin "Load Modules".
  • Create a modul of type Viscarousel
  • Choose a position which is not used by your template for example carousel1. You can just type the name into the input of the select field.
  • Publish the module (Status Published)
  • Set "Menu Assignment" to "On all Pages".
  • Insert {loadposition carousel1} into your article where you want the carousel to be shown. You have to change "carousel1" according to the value you choose as module position.
You can learn how to further adapt the display of the carousel inside the article by reading Publishing Options.
Article list
