Data Export in excel
9 Jahre 8 Monate her #3457 von brijesh4534
Data Export in excel wurde erstellt von brijesh4534
I have a form in my website, now the result is saved in the database. To add those visitors in my CRM system i have to create an excel of the data which i do by exporting the database table from the database and then inserting it into the excel.
Is there a way to do it directly from the visform?????
9 Jahre 8 Monate her #3460 von Administrator AV
Administrator AV antwortete auf Data Export in excel
you can create a csv export directly with Visforms.
Use the export button in the "data list view" in the administration.
You can customize the export.
There are options for the export to set in the form configuration (tab advanced) and in the field configuration (tab advanced) of each field.
Take a look at the documentation, section "Exporting saved data"
www.vi-solutions.de/en/documentations/vi...rms/314-save-results
9 Jahre 8 Monate her #3466 von brijesh4534
brijesh4534 antwortete auf Data Export in excel
I updated my joomla to 3.6.1 and updated the visforms to 3.8.7 on creating the form when i add title and alias and click on any save button nothing happens, and when i click in the cancel button it gets redirected to visforms main screen.
can you provide me a solution for this.????
9 Jahre 8 Monate her #3468 von Administrator AV
is this problem specific to Visforms?
Can you create a new Joomla! article and save it or do you have the same problem there.
Folgende Benutzer bedankten sich: brijesh4534
9 Jahre 8 Monate her #3470 von brijesh4534
yes, there was an sql updation error from extensions--> manage-->database clicked on fix and every thing was solved.
9 Jahre 8 Monate her #3471 von Administrator AV
thanks for sharing the solution!
