Urgent problem with Summary
7 Jahre 2 Wochen her #6170 von AndyG0HXT
Urgent problem with Summary wurde erstellt von AndyG0HXT
Hi
We recently purchased a subscription for Visforms.
I have created a new form that has a lot of fields with conditions and I have enabled the Summary page option. Everything was working fine but suddenly without any changes to the form the Summary button does not respond. If you leave a required field empty and select the summary button Visforms tells you the field is required however, you cannot move beyond the summary button and can't get to see the summary page.
Can you tell me what could be wrong or some things to try?
Thanks
7 Jahre 2 Wochen her #6171 von Administrator AV
Administrator AV antwortete auf Urgent problem with Summary
Hi, I,m not exactly sure if I understand correctly. You have to enter valid values in each field, before you can got to the summary page.
So does the summary button not work even, after you have corrected all invalid user inputs? If so I would need to take a look at the form.
Regards Aicha
7 Jahre 2 Wochen her #6172 von AndyG0HXT
AndyG0HXT antwortete auf Urgent problem with Summary
Hi, thanks for the quick reply. Yes if the form has all the fields with options set the summary button does not respond.
7 Jahre 2 Wochen her #6173 von Administrator AV
ok, as I told, I then need to take a look at the form directly in order to check what might be the problem.
Have you updated visForms and the subscription to the latest versions (3.12.10/3.3.11)?
There actually was a bugfix for the summary page feature in the subscription 3.3.11 update. (See: www.vi-solutions.de/en/documentations/do...tion-release-history )
7 Jahre 2 Wochen her #6174 von AndyG0HXT
Hi, thanks for the update. Thinking about it.... the last thing I did at the weekend was to upgrade to 3.12.10. Can I downgrade back to where I was to test the form again?
I can arrange for a remote session for you to see the form. I'm not able to grant you administration access independently however, via a remote session I can log you in etc.
7 Jahre 2 Wochen her - 7 Jahre 2 Wochen her #6175 von Administrator AV
Have cleared cached javascript from the browser cache?
Downgrading is no option.
Do you have any javascript errors in the browser console?
Have you upated the subscription to 3.3.11, too?
Letzte Änderung: 7 Jahre 2 Wochen her von Administrator AV.
