SOME INPUTS ARE NOT VALID A value, sumbitted for..
10 Jahre 7 Monate her - 10 Jahre 7 Monate her #2086 von d2dpcs
Nice component so far!
I get the following error when testing my first form with Visform.
A value, sumbitted for the field "If Yes (select your ad size)" is invalid.
url: www.ropl.org/pin
Thanks.
Letzte Änderung: 10 Jahre 7 Monate her von d2dpcs. Begründung: Marked as answered
10 Jahre 7 Monate her - 10 Jahre 7 Monate her #2087 von d2dpcs
Hmm... I turned off all of the spam options and it worked the first time afterwards. Second and third attempts show the error again. Thanks for your help.
10 Jahre 7 Monate her #2088 von Administrator AV
Administrator AV antwortete auf SOME INPUTS ARE NOT VALID A value, sumbitted for..
thanks for your post.
It would be helpful to know the Visforms and Joomla! versions.
I tested the form twice (in a row) without problems.
Do you receive exactly this message text SOME INPUTS ARE NOT VALID (in upper case)? Because in Visforms you would receive either this message text in lower case or an untranslated language tag, but the tag is COM_VISFORMS_FORM_HAS_INVALID_INPUTS.
The message "Some inputs are not valid" is only a header, which should only be displayed in combination with another error message line, that specifies which inputs are not valid.
So, if the problem is still there, I need some more information.
10 Jahre 7 Monate her #2102 von d2dpcs
I am using Visforms 3.5.7 and Joomla 3.4.4.
I didn't get a confirmation email that you submitted the form successfully.
Yes, the message text is all caps... probably due to my template css. My original post did state the field that is invalid:
"A value, sumbitted for the field "If Yes (select your ad size)" is invalid."
Thanks,
Eric
10 Jahre 7 Monate her #2103 von Administrator AV
Hi Eric,
I'm not sure, but one problem with these radio-buttons is, that you entered the full description text again as option value. You are using " an '' and many special characters in the option value and that does break the form. For example the source code for one option looks like that:
<input id="field19_3" class=" inputbox visCSSbot5 " type="radio" aria-labelledby="ad-sizelbl ad-sizelbl_3" ($250)"="" color="" full="" cover,="" front="" or="" back="" inside="" 3.75"),="" x="" value="1/2 page (4.5" name="ad-size">
So when a user submits the option the submitted value is
but the original value, which you entered in the field configuration and against which the php validation checks is
1/2 page (4.5" x 3.75"), inside back or front cover, full color ($250)
This is, why the php validation fails and the error message is send.
So please change the texts of your option values and avoid the special characters (at least single or double quotes).
I think I have to add a validation in the field configuration, to avoid at least special characters like " in the option value.
10 Jahre 7 Monate her #2104 von d2dpcs
Aicha,
Yes, that was it. I removed the " and it works fine. Thanks!
