System Requirements
Module Viscarousel is a extension for Joomla! 3.x. Compatible Joomla! 3.x You need a fully functionable installation of Joomla! 3.x to use this module.. The module is NOT compatible with Joomla 4. We will not provide a version of the module for Joomla 4.
Viscarousel is a Bootstrap Carousel designed for Bootstrap 2.3.2 which is the Bootstrap version that comes with Joomla! 3.x by default. It will not work properly without a Bootstrap template, that includes the Bootstrap 2.3.2 Javascript and CSS files. If you are not sure, whether your template do fulfill this requirements, please ask your template developer or check on his website. The Protostar template, that comes with Joomla! 3.x, fulfills the requirements.
Module Viscarousel is fully compatible with the Joomla! 3.x core framework functions and scripts. We cannot guarantee for it's compatiblity with any 3rd party Joomla! extensions.
Neither Joomla! 3.x nor Bootstrap 2.3.2 nor the Javascript they rely on work flawless on older browsers. Therefore Bootstrap Carousels, created with this module may not work properly either. Or you may have problems with module configuration in the administration panel.
The installation package includes English and German language files for backend and frontend.
Article list
