Display data, submitted with a Visforms form, inside a module
We propose reading the documentation from the beginning, starting with the Introduction. We will not repeat concepts and explanations made in previous parts of the documentation, here.
The content plugin Data View allows you to display user inputs submitted with a form created with Visforms form inside a module of type "Custom HTML". You have to add a plugin string to the module's text at the place where you want to display the data. The plugin will find the string, remove it and insert the data viiew instead.
Please follow the instructions Display data in article, in order to create the proper plugin string, if you want to display a data in a module.
Create a module of type "Custom HTM and set up the module position, Menü links, etc. as usual.
Enable the Option "Prepare Content" in the modul "Options" tab. This is necessary in order to perform content plugins - as the content plugin data view - in modules!
Article list Find suitable subscription
