Vis Forms Multilanguage problem
10 Jahre 3 Wochen her #3443 von Modjo
Vis Forms Multilanguage problem wurde erstellt von Modjo
Hello I need help, I use Vis Forms and I'm very happy with it, but in a multilanguage site that I'm finishing a problem came out:
The main language is Portuguese here all is ok the form show up no problem, but when I change to English or spanish the other 2 languages, the form just dont show, tried with new forms all that I could think.
Could ypu please check my website I see if you could find the problem?
carenavig.com/web/index.php/contatos
carenavig.com/web/index.php/es/contatos-es-es
carenavig.com/web/index.php/en/contact-us
Thanks
Jorge Amaro
10 Jahre 3 Wochen her #3444 von Administrator AV
Administrator AV antwortete auf Vis Forms Multilanguage problem
Hi Jorge,
Visforms fully supports the Joomla! core multi language feature (which actually means that you have an individual menu item for each language). You have to create a form for each language. You can use the batch copy function in the form list view in the administration to duplicate your form and set the language. Or you have to change the language after batch copying the form.
Make sure that all forms and fields are published. Create a menu item with the proper language for each form. And link it to the proper form.
This here is a multi language website, too. And as you can see I use the multi language feature of Visforms for my demo forms as well and it works fine.
So if the forms don't show up, most probably the language of the selected form and the language of the menu item do not match.
10 Jahre 3 Wochen her #3446 von Modjo
Modjo antwortete auf Vis Forms Multilanguage problem
Thanks, but i tried what you said I created a simple form from scratch and choose the language to english. In the menu also each language have is menu.
As you can see in this link carenavig.com/web/index.php/en/contact-us the form that I put on english dont apear, but if I put this form on the portuguese language it apear.
Sorry for wasting you r time, but i think the reply is in front of my eyes, but I ca't see it.
If you want I could send to you the login of the backoffice
Thanks once again
10 Jahre 3 Wochen her #3448 von Administrator AV
yes I think there is a misconfiguration of the language on your website and sometimes one just cannot see it.
I can look into this, if you like too but I have to charge for me work. If offer a support ticket for such cases. I'm sure we can solve the problem even if it might take me a bit of searching, too.
10 Jahre 3 Wochen her #3450 von Modjo
Let me talk to my boss
Thanks
