Custom Field Problem
9 Jahre 6 Monate her #3704 von fede491
Custom Field Problem wurde erstellt von fede491
Hi Aicha,
I'm using Visforms version 3.8.9 and I’m using the custom field extension, but I have a problem:
If I use this formula:
([FATTURATO] >= 50000) ? ([FATTURATO]*0.012) : 0
everything works fine
but I use this:
([FATTURATO] <= 50000) ? ([FATTURATO]*0.012) : 0
after saving, the text is modified in this way
([FATTURATO] FATTURATO]*0.012) : 0
and of course the calculation does not work I’ve the same problem although I use only the less than sign (<)
This is very strange for me...
9 Jahre 6 Monate her - 9 Jahre 6 Monate her #3705 von Administrator AV
Administrator AV antwortete auf Custom Field Problem
thanks for the post.
I will check into this as soon as possible.
As the greater sign seem to work, maybe as a workaround you can just switch the order.
(50000 > [FATTURATO])
Letzte Änderung: 9 Jahre 6 Monate her von Administrator AV.
9 Jahre 6 Monate her #3706 von Administrator AV
I was able to reproduce the problem and to figure where it comes form.
It is easy to fix.
Please open the file administrator/components/com_visforms/models/forms/visfield.xml
At line 707 - 709 you find the following code
<field name="f_calculation_equation" type="textarea" label="COM_VISFORMS_CALCULATION_EQUATION" description="COM_VISFORMS_CALCULATION_EQUATION_DESC" class="inputbox" rows="5" />
replace it with
<field name="f_calculation_equation" type="textarea" label="COM_VISFORMS_CALCULATION_EQUATION" description="COM_VISFORMS_CALCULATION_EQUATION_DESC" class="inputbox" rows="5" filter="raw" />
I will add the fix to the Visforms core, so that it will be release with the next version.
9 Jahre 5 Monate her #3758 von fede491
fede491 antwortete auf Custom Field Problem
Thank you!!!
9 Jahre 5 Monate her #3760 von Administrator AV
You're very welcome and I have to thank you for pointing me to a bug in Visforms!
Kind Regards,
