Display calculation field after input all fields
6 Jahre 7 Monate her #6321 von hooman52
I have two fields of Date type. "From date" and " To date". and another field that calculates number of days between these to fields. when I enter a date for "From date" field, "Number of days" filed immediately displays -18198. after I enter date for " to date" it displays correct calculation.
I need to hide this wrong calculation (-18198) and force "Number of days" field to display result after both of dates are entered.
Let me ask you help to solve it.
Thanks.
6 Jahre 7 Monate her #6322 von Administrator AV
Administrator AV antwortete auf Display calculation field after input all fields
I'm sorry, but the calculation is always done instantanliously.
As soon as the value of any field, which is used in the calculation, is changed, the value of the field of type calculataion is recalculated.
There is no way to prevent this.
So the only possibility I can see is, that you set a default value for the date from and the date to field which is a number of days in the future relative to the current date. Maybe you can find "good" default values, so that the calculation looks good.
