How to display text-input field output in "uppercase"
4 Monate 1 Woche her #12285 von herb200mph
Client would like the text-input fields to display as all UPPERCASE letters, regardless of how information is entered.
How/Where do we change the CSS to force the from message to display the field entry in UPPERCASE?
Thank you again for your assistance.
BTW client is using our choice of Visiforms as the platform to send emergency messages to tenants of high-rise buildings when an incident arises.
HERB
4 Monate 1 Woche her #12287 von Administrator IV
Hello HERB,
Re: Where do we change the CSS?
You don't need to modify any existing CSS; you add your own specific CSS to, for example, a form or a data view.
How to do this is described in the documentation.
You can achieve this behavior with custom CSS and the Visforms 'Frontend Webassets'.
JavaScript is also possible this way.
Frontend Web Assets:
docs.joomla-6.visforms.vi-solutions.de/e...-frontend-webassets/
All settings are made in the form:
docs.joomla-6.visforms.vi-solutions.de/e...are-made-in-the-form
CSS examples:
docs.joomla-6.visforms.vi-solutions.de/e...amples/examples-css/
Regarding Visforms CSS and template CSS, the following information may be of interest to you.
HTML and CSS Structure >> Introduction >> Visform’s Unique Passive Integration Strategy:
docs.joomla-6.visforms.vi-solutions.de/e...integration-strategy
BTW your customer application sounds very interesting.
Kind regards, Ingmar
