How to add Checkbox options in visforms
10 Jahre 7 Monate her #2333 von brijesh4534
How to add Checkbox options in visforms wurde erstellt von brijesh4534
I'm using Visforms Version 3.1.2, and there is an option to add checkbox, now i selected the check box option but was not able to add various options for the check box menu
Please help
10 Jahre 7 Monate her #2334 von Administrator AV
Administrator AV antwortete auf How to add Checkbox options in visforms
Visforms 3.1.2 is quite an old versions and in this version there are no chockbox groups. So a checkbox always is a single checkbox and you cannot add various options to one checkbox but only one value (which you have to enter in the "Value" option.
If you want something with more options you have to use the field type select which will create a listbox/dropdown.
Folgende Benutzer bedankten sich: brijesh4534
