Form Data Display not working
9 Jahre 3 Monate her #4201 von mikepritchard
Form Data Display not working wurde erstellt von mikepritchard
I am using
Visforms Version 3.8.21
Joomla 3.6.5
Using the menu to create a form data page is not working anymore, you can see my test here:
apldwa.org/test-of-registration-form-display
(should show 2 registrations)
But the problem is only with the new form I just created after the recent Vis Forms update.
The old form created before the recent Vis Forms update still works:
apldwa.org/form-data-test-display-with-free-form
I have checked all the form settings three times. Everything is identical to the old, working forms.
Do you have any advice?
9 Jahre 3 Monate her #4202 von Administrator AV
Administrator AV antwortete auf Form Data Display not working
I took a look at the two links.
I don't think, that you problem originates from the Visforms update.
As far as I can see, on the site, where the data are not displayed (the new form), the view is not displayed at all.
In my opinion there are two possible reasons for this.
First: Visforms checks, if a user is allowed to view the data and if everything is correct with the data. If not, if will return without displaying any data but adds an error message to the Joomla! message queue. If your template does not display messages passed to the Joomla! message queue properly, this would just result in what I can see on your website. (Just nothing)
Second: The form is not published (I think this is quite unlikely) but this would give the same result.
9 Jahre 3 Monate her #4206 von mikepritchard
mikepritchard antwortete auf Form Data Display not working
Thank you for the info. I turned on error reporting, debug and checked the Joomla error logs. I also created a new link to display only the missing info. There are 10 registrations on this form:
apldwa.org/registration-test-form-display2
There are no errors reported on that page.
The Joomla error log shows this error today:
[18-Apr-2017 06:30:58 America/Chicago] PHP Notice: Undefined property: JObject::$list.limit in /home/apldwa/public_html/components/com_visforms/models/visformsdata.php on line 701
and four times yesterday.
The best I can tell that error refers to this line:
'limit' => $this->state->{'list.limit'},
Another recent error that is repeated many times is:
[13-Apr-2017 18:15:26 UTC] PHP Notice: Undefined variable: tmpl in /home/apldwa/public_html/components/com_visforms/controllers/visforms.php on line 238
In the debug file, in Database Queries it says:
5 duplicate found!
3 duplicates: #13 #20 #24
2 duplicates: #19 #21
I can't copy the entire log and can't leave debug on.
But this is the report from #13:
Query Time: 0.14 ms After last query: 4.33 ms Query memory: 0.027 MB Memory before query: 3.702 MB Rows returned: 0
Duplicate queries: #20 #24
SELECT *
FROM `mb6fy_visfields`
WHERE `fid` = 10
AND `published` = 1
AND `frontaccess` in (1, 1, 5)
AND `typefield`not in ('reset', 'submit', 'image', 'fieldsep')
AND (`frontdisplay` is null or `frontdisplay` in (1,2,3))
ORDER BY `ordering` asc
Explain
id select_type table type possible_keys key key_len ref rows Extra
1 SIMPLE mb6fy_visfields ALL NULL NO INDEX KEY COULD BE USED NULL NULL 53 Using where; Using filesort
Profile
Status Duration
starting 0.03 ms
Waiting for query cache lock 0.00 ms
init 0.00 ms
checking query cache for query 0.01 ms
checking privileges on cached 0.00 ms
checking permissions 0.01 ms
sending cached result to clien 0.01 ms
updating status 0.00 ms
cleaning up 0.01 ms
Call Stack
# Caller File and line number
15 JDatabaseDriverMysqli->execute() JROOT/libraries/joomla/database/driver.php:1689
14 JDatabaseDriver->loadObjectList() JROOT/components/com_visforms/models/visformsdata.php:411
13 VisformsModelVisformsdata->getDatafields() JROOT/components/com_visforms/models/visformsdata.php:100
12 VisformsModelVisformsdata->__construct() JROOT/libraries/legacy/model/legacy.php:204
11 JModelLegacy::getInstance() JROOT/libraries/legacy/controller/legacy.php:547
10 JControllerLegacy->createModel() JROOT/libraries/legacy/controller/legacy.php:728
9 JControllerLegacy->getModel() JROOT/components/com_visforms/controller.php:68
8 VisformsController->display() JROOT/libraries/legacy/controller/legacy.php:702
7 JControllerLegacy->execute() JROOT/components/com_visforms/visforms.php:24
6 require_once JROOT/components/com_visforms/visforms.php JROOT/libraries/cms/component/helper.php:405
5 JComponentHelper::executeComponent() JROOT/libraries/cms/component/helper.php:380
4 JComponentHelper::renderComponent() JROOT/libraries/cms/application/site.php:191
3 JApplicationSite->dispatch() JROOT/libraries/cms/application/site.php:230
2 JApplicationSite->doExecute() JROOT/libraries/cms/application/cms.php:261
1 JApplicationCms->execute() JROOT/index.php:49
[Add xdebug.file_link_format directive to your php.ini file to have links for files.]
I would appreciate any help.
Thanks much,
Mike
9 Jahre 3 Monate her #4210 von Administrator AV
Hi Mike,
I was not talking about errors which are reported through debug configuration and error logs but of messages, like you are not permitted to view this page, which are passed through the Joomla! message queue and displayed with the jdocs include type="message" in your template.
9 Jahre 3 Monate her #4211 von mikepritchard
yes, there are none of those.
9 Jahre 3 Monate her #4212 von Administrator AV
could you give me access to the administration of the website? You could send me the required information to contact@vi-solutions.de
