Form Data Display not working
9 Jahre 4 Monate her #4213 von mikepritchard
mikepritchard antwortete auf Form Data Display not working
just sent, thanks much.
9 Jahre 4 Monate her #4214 von Administrator AV
Administrator AV antwortete auf Form Data Display not working
you forgot to enable the display data in frontend on field level. (Field configuration, tab "advanced").
9 Jahre 4 Monate her #4215 von mikepritchard
I must be blind because I can't find that anywhere. Is that on the form advanced tab?
9 Jahre 4 Monate her #4216 von Administrator AV
FIELD configuration
You have to set for each field individually, that the data submitted for this field, are visible in the front end.
9 Jahre 4 Monate her #4217 von mikepritchard
Got it. I have never set that before, the default must have changed at some point to:
Display Data In Frontend: (Don't Show)
I am including my notes here in case anyone else has this problem:
not only do you create the menu item you also have to be sure to set:
Your Form/ Result to save results,
Your Form/ Dataview in Frontend set to Allow...
Your Form/ each field must be set individually. Click on Advanced tab in the individual field then under Usage change "Display Data in Frontend to "list and details"
Thanks,
Mike
9 Jahre 4 Monate her #4218 von Administrator AV
the default was changed years ago, because with the original default settings there could be an unintentional discloser of user data.
Thanks for your brief and helpful notes. You missed one setting
Your Form/ Data view in Frontend set Autopublish Data to Yes
