SQL
6 Jahre 3 Monate her #6526 von av_74
SQL wurde erstellt von av_74
Hello
I would like to fill in a Select field using an SQL query: SELECT * FROM `aspt_visforms_1`
But I can't find where to put this request
Thank you for your help
Visforms Subscription Visform 3.12.10
6 Jahre 3 Monate her #6528 von Administrator AV
Administrator AV antwortete auf SQL
the fields that can create options form sql-Statements (listboxsql, radiosql and multicheckboxsql) where added to visForms 3.13.x/subscription 3.4.x, which are currently available as beta versions.
You have to update to visForms 3.13.9 and Subscription 3.4.7, if you want to use this feature.
As we do not distribute beta versions via Joomla! update manager, you have to download the installation packages from the downloads menu manually.
6 Jahre 3 Monate her #6530 von av_74
av_74 antwortete auf SQL
Thank you the SQL fields appear now
When I test the request I have: success: found 10 entries
but they do not appear in the Select field of the form
6 Jahre 3 Monate her - 6 Jahre 3 Monate her #6531 von Administrator AV
if you use the sql statement
this can obviously not work.
Which information from this * should be use in the option list?
As stated in the documentation ( www.vi-solutions.de/en/documentations/do...m-database-using-sql ), which I would like you study carefully, "The SQL statement must return a value and a label"!
Letzte Änderung: 6 Jahre 3 Monate her von Administrator AV.
6 Jahre 3 Monate her #6532 von av_74
sorry I forgot to specify the field
SELECT `F1` FROM `aspt_visforms_1` WHERE 1
but it doesn't work :(
6 Jahre 3 Monate her #6533 von Administrator AV
please check out the documentation. "The SQL statement must return a value and a label"!
Your sql-Statement is still not correct. It cannot work with regards to creating listbox options.
