SQL
6 Jahre 6 Monate her #6534 von av_74
av_74 antwortete auf SQL
Sorry, I don't speak English well. I use google translation but the approximate translation does not allow me to fully understand how SQL fields work. I'm trying to fill a select field with a field from a Visform table ...
6 Jahre 6 Monate her #6535 von Administrator AV
Administrator AV antwortete auf SQL
HI,
your sql must be something like
select id as value, F1 as label from aspt_visforms_1
the as value and as label must be there!
value and label which are returned by the sql statement are use to create the options
6 Jahre 6 Monate her #6536 von av_74
Sorry I did not understand Indeed my SQl request was not good. Now it works: SELECT id as value, F1 as label FROM `aspt_visforms_1` limit 20
Thank you very much for your help, I hope I did not waste you too much time.
Thanks again
