Using JCE instead of TinyMCE
5 Jahre 2 Monate her #7272 von djmelville
Using JCE instead of TinyMCE wurde erstellt von djmelville
Is there a way to change the default editor in Visforms back-end component to use my system-defailt editor JCE instead of the primative TinyMCE?  Thank you.
5 Jahre 2 Monate her #7274 von Administrator AV
Administrator AV antwortete auf Using JCE instead of TinyMCE
no there is not, because the JCE does not support multiple instances of the editor in one administrator form properly.
It would not possible to use the Editor-Plugins like the button which is used to insert Visforms Placeholder into the texts.
