Frontend display page - deleting and markingrecord
12 Jahre 1 Monat her #231 von Barbar
Hello,
is possible to add in to Frontend display page - for every record, a button to deleting selected record and checkbox for marking record (for example mark for complete task)?
Thanks for Your reply.
B.
12 Jahre 1 Monat her #234 von Administrator AV
Hi Barbar,
allowing users in frontend to delete submitted form data is big step in a new direction which I deem very dangerous. You would have to think very carefully about the process itself and it's "access control" in particular. I'm not quite sure about it, but I think that even image galleries do not allow frontend users to delete data (images).
I'll consider that as a feature request but I think that it is more probable that I will not implement it.
Kind Regards,
12 Jahre 1 Monat her #239 von Barbar
Hi Aicha,
thank you for your quick reply.
I understand, that deleting entry is dangerous.
Here is another idea from me (only idea - I'm not programmer):
adding checkbox - or any way for marking as read (done task) and in next time don't show this entry on Frontend display page.
Barbar
12 Jahre 1 Monat her #240 von Administrator AV
Hi Barbar,
the feature you describe is one, that I in principle I had in mind for further development, but for the backend, not the frontend. It's aim would be to deliver a parameter to select which submitted data are displayed in frontend and which not. That leads away from a "Form Generator" to a "Management System" so there is lots to think on.
Thanks for your ideas and suggestion.
Kind Regards,
12 Jahre 1 Monat her #241 von Barbar
Hello Aicha,
I'll wait for what will be the ultimate solution, but also manage items in the backend is a partial solution for me - now I have to delete records in a SQL database (but not a solution for a user who has access only to the frontend page).
nk you for your answers and your work.
Barbar
  • luiaard
12 Jahre 1 Monat her #275 von luiaard
I am using VI Forms for a list with clients and data about actions connected with these clients. Since clients data changes, it would be helpfull to be able to edit records in front-end. It would also be helpfull if I could filter the output by client or any other field.
Hope you can help me.
