Date Field and Submit fonction problem
2 Jahre 10 Monate her #9418 von viga
Date Field and Submit fonction problem wurde erstellt von viga
Hello,
Like many of us, I am having some issues.
When I put a Date type field, the SUBMIT function/button no longer works.
Same phenomenon with the upload file field, the SUBMIT button on the form is no longer active.
Do you have an explanation or advice.
It's an up-to-date Joomla 4
2 Jahre 10 Monate her #9419 von Administrator IV
Administrator IV antwortete auf Date Field and Submit fonction problem
hello viga,
this is an intended behavior of the form.
Because then you have a JavaScript error on your website.
Citation:
As a complex form component, Visforms depends on the JavaScript on the page to function properly.
If you have a JavaScript error on the page, the button will remain disabled
You can assume that the occurring JavaScript error is not causally connected to Visforms.
This behavior and help on how to fix it is part of the documentation.
Submit button is greyed out (disabled):
docs.joomla-4.visforms.vi-solutions.de/e...-greyed-out-disabled
In order to make this behavior easier to understand, an additional explanatory or warning notice directly on the page would certainly make sense for the user.
Issue [VF-836] Forum: Submit button is greyed out: Add explanatory message to the page
Thank you for your contribution!
Kind regards, Ingmar
