Breezing form migration problem
1 Jahr 1 Woche her - 1 Jahr 1 Woche her #11322 von oficinamediaes
Breezing form migration problem wurde erstellt von oficinamediaes
The migration from breezing forms.was done with one click but there are some elements that were not migrated correctly.
Example:
1) I had some forms divided into 2 pages (the migration put everything on the same page).
2) I had some hidden elements that did things and that were not migrated.
How can I migrate what is missing?
Letzte Änderung: 1 Jahr 1 Woche her von oficinamediaes.
1 Jahr 1 Woche her #11324 von Administrator IV
Administrator IV antwortete auf Breezing form migration problem
Hello oficinamediaes,
The BreezingForms import is described in the documentation.
There, among other things, it describes what can be imported, what can't be imported, and why.
The following cannot be imported:
- Question 1: the missing structure (multi-page form) and
- Question 2: the missing elements, which are not actual input fields for the user and perform various other functions.
Basically, after the import, all essential elements, especially all input fields and user data, are present.
Import BreezingForms:
docs.joomla-5.visforms.vi-solutions.de/e...reezingforms-import/
2 quotes from the documentation:
Note: The import affects basic properties of the forms and all fields in which the user makes entries.
Advanced settings and logic are lost during import due to the very different structures.
Note: Fields in Breezingforms that are not intended for the actual entry of user data cannot be imported.
Kind regards, Ingmar
11 Monate 5 Tage her #11449 von oficinamediaes
oficinamediaes antwortete auf Breezing form migration problem
Thanks for the reply.
I understand what you are saying but, at the same time, the imported form does not work as well and I do not understand why.
Forgetting non-imported items, after filling in all the fields I cannot send it.
Sending screenshot.
Could I get some support on this?
11 Monate 2 Tage her #11451 von Administrator IV
Grayed-out and therefore unclickable submit and reset buttons are intentional.
If a JavaScript error occurs on the page, JavaScript execution stops prematurely at that point.
The very last step of form initialization enables both buttons.
This step is not executed if a JavaScript error occurs on the page.
This is important and intentional, as form validation and many other functions, such as security aspects, depend on error-free JavaScript execution.
There is an entry on this topic in the FAQ section of the Visforms documentation.
Submit button is disabled and does not work:
docs.joomla-5.visforms.vi-solutions.de/e...-button-not-working/
10 Monate 3 Wochen her - 10 Monate 3 Wochen her #11472 von oficinamediaes
Thanks, I fixed the issue in the frontend but there is something still not working in the backend.
I can't create a success page right now.
Please watch the video on this url:  serinfondemo7.com.es/Backend-problem.mp4
Can you please help me get the extension working properly?
Letzte Änderung: 10 Monate 3 Wochen her von oficinamediaes.
10 Monate 3 Wochen her #11473 von Administrator IV
Option 1:
You can enable debugging to see if there is a PHP error.
If there is a PHP error, the entire call stack would be important for us:
- Copy from the page with the ad,
- Save to file,
- Upload the file to the forum post.
To get an accurate PHP error report, enable maximum debugging in the Joomla administration before reproducing the error:
Option 2:
The simplest and fastest way to proceed is the following.
The question is whether you could provide us with an Akeeba backup of the website for debugging.
Use the forum email address as the recipient: forum (--at--) vi-solutions.de.
Administrative access to the backend is not sufficient in this case.
