form does not work
11 Jahre 10 Monate her #964 von imkejoemrati
form does not work wurde erstellt von imkejoemrati
hi installed visforms 3.1.1 on a website. i made a few forms, non of them work. On the website, i cannot fill in any text field. de date fiels, does not display a calender,
can you take a look at bzvsuriname.com/web/index.php/2014-10-27...ce/individueel-gezin
Please help
Regards
11 Jahre 10 Monate her #965 von Administrator AV
Administrator AV antwortete auf form does not work
I will look into that tomorrow.
11 Jahre 10 Monate her #969 von Administrator AV
the default.css of your template sets the font color of elements with class inputbox to #ffffff. (line 124)
As Visforms uses this class for inputs, sets the background-color to white and does not set a text-color of its own background and font color are both white with your template.
Therefor you cannot see what you type into the inputs but actually it is there.
Folgende Benutzer bedankten sich: imkejoemrati
11 Jahre 10 Monate her #982 von imkejoemrati
imkejoemrati antwortete auf form does not work
thank you very much for the quick response. It works!
One last question.The colors of the labels are light blue, where can i change that?
11 Jahre 10 Monate her #983 von Administrator AV
every modern browser has built-in developer tools which you can use to find out which css rule in which css file is used to style a html element.
Looking into the individual configuration of your website is far more than you would usually expect as support for a free component. Nevertheless I will help you once more. But actually I would be very glad if people would honor such service with a donation and do not take it for granted (as it sadly happens very often).
The color is defined in the default.css at line 143 where the rules for the html label tag are declared.
Good luck and Kind Regards,
11 Jahre 10 Monate her #984 von imkejoemrati
thank you aicha,
but the date fields still do not work
