Problems with html editor textarea
11 Jahre 7 Monate her #1303 von Administrator AV
Problems with html editor textarea wurde erstellt von Administrator AV
I just noticed, that the bootstrap default layout and the bootstrap horizontal layout do not show an HTML editor when you check the field parameter "HTML Editor" for a field of type textarea.
This is a small bug, which I will fix with the next release. This is only a bug in Visforms 3.2.0 to 3.2.6.
You can fix the bug yourself.
Open components/com_visforms/lib/html/field/textarea.php
Go to line 42
Replace
if ($value)
with
if ($value || $name='attribute_class')
