Problème d'enregistrement dans le menu Champ
11 Jahre 7 Monate her #1319 von priam
Bonjour,
Impossible d'enregister toute modification de champ (version 3.3.0 sous jooomla 3.3.3) : pas de remise en ordre possible, pas de champ supplémentaire possible...).
--> Obligation de quitter le mode adminstrateur de Joomla.
Avez-vous déjà eu connaissance de ce problème ?
Merci de votre réponse.
Cordialement.
Hervé
11 Jahre 7 Monate her #1320 von priam
Hello,
Can not record any field modification (version 3.3.0 jooomla under 3.3.6): no restoration possible order, no possible additional field ...).
-> Obligation to leave the adminstrator mode Joomla.
Have you ever heard of this?
Thank you for your response.
Best Regards.
Hervé
11 Jahre 7 Monate her #1325 von Administrator AV
Administrator AV antwortete auf Problème d'enregistrement dans le menu Champ
Hi Hervé,
that is very strange. Actually I have heard from exactly one other person, that the menu buttons in field configuration (Save, Save&Close, Close and so) do not work, and this person runs a french website, too!
But I cannot reproduce the problem on my test systems and have not heard of it otherwise.
Most probably this is a Javascript problem, because all buttons and the order function use Javascript. Maybe you can use the Browser Console to find if there is a Javascript error and what the error message says.
Maybe you could enable the "Debug System" and set the "error reporting" to "Maximum" (in Global configuration) in order to get some more information about the problem.
You could enable "Language Debug" in global configuration. Maybe there is an error in the french language file.
Let me know, what you find out.
11 Jahre 7 Monate her #1345 von priam
Hello Aicha.
I uninstalled the extension in French and everything is working properly (in English).
Best Regards,
Hervé.
11 Jahre 6 Monate her #1359 von Pat
Salut Hervé
Je m'occupe de la traduction en Français de cette excellente base de données qu'est visform.
J'ai remonté à Aicha ce problème et nous sommes sur le problème.
J'ai complété pour commencer la traduction de la dernière version, sans résultat.
Je suis entrain de regarder les fichiers php auxquels correspondent les boutons, mais je n'ai encore rien trouvé de probant.
Je vais regardé dans les javascript.
Si tu as désinstallé la traduction et que cela fonctionne, peux-tu me le confirmer pour être sur que cela vienne bien d'un lien de traduction. Je ne peux pas à la fois regarder les fichiers et faire des tests, cela me disperserait. :pinch: :sick: :side:
A+
11 Jahre 6 Monate her #1361 von Pat
Salut Hervé,
J'ai trouvé l'erreur.
J'ai traduis 2 textes qui devaient rester en anglais.
Maintenant que j'ai fait l'erreur, je ferai plus attention les prochaines fois afin d'éviter de planter ton site.
J'ai envoyé les fichiers à Aicha.
Si tu as une adresse mail je te les envoies dès que tu posteras ton message.
Il est vrai que la version 3.3 apporte bien des nouveautés très utiles.
:woohoo: Les yeux grand ouverts à partir de maintenant. :woohoo:
