Not show multi column
11 Jahre 2 Monate her #1743 von toonytoony2004
Not show multi column wurde erstellt von toonytoony2004
Version : Visforms 3.5
i try to set form for multi column but not show multi column. i not use bootstrap on my joomla template,
1. try to set in advanced for multi column layout .. not show.
2. try to set in advanced in field for width value 4 ... notshow..
Please how to more set for multi column or add css for solve it.
thanks
[img
A Friend Never Forget
11 Jahre 2 Monate her #1746 von Administrator AV
Administrator AV antwortete auf Not show multi column
as I stated in the documentation that explains how to set up a multi column form. This feature does only work with a template that implements bootstrap 2.3.2 (the default, for Joomla! 3).
