Multicolumn problem
10 Jahre 5 Monate her #2846 von manx
Multicolumn problem wurde erstellt von manx
I know your extencion use "spanX" class for column creation. But it is no longer supported by Bootsrap. For some time Bootstrap use "col-sm-X" class for column grid. Do you have in plans to update "spanX" to "col=sm-X" class ?
10 Jahre 5 Monate her #2848 von Administrator AV
Administrator AV antwortete auf Multicolumn problem
the default Boostrap Framework included with Joomla! is still 2.3.2 wich uses spanX.
Creating new layouts for Visforms is quite a bit of work.
I will create Boostrap 3 compatible layouts for visforms when Joomla! changes the default.
I think they will somehow provide the tools to handle Bootstrap 3 properly.
