Not compatible with PHP v7.1
  • cd5aac5f206d1be91cada9f7
  • Topic Author
8 years 8 months ago #5300 by cd5aac5f206d1be91cada9f7
Not compatible with PHP v7.1 was created by cd5aac5f206d1be91cada9f7
Dears,
After migrating to PHP v7.1 and activating the Spambotcheck plugin, I get following errors thrown back.
Looks like the plugin is not compatible with PHP v7.1.
After disabling the plugin, the site works again.
Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; plgUserSpambotCheck has a deprecated constructor in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 17 Notice: Use of undefined constant DS - assumed 'DS' in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Notice: Use of undefined constant DS - assumed 'DS' in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Notice: Use of undefined constant DS - assumed 'DS' in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Notice: Use of undefined constant DS - assumed 'DS' in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Notice: Use of undefined constant DS - assumed 'DS' in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Warning: require_once(/customers/3/5/0/mysite.comhttpd.wwwDSpluginsDSuserDSspambotcheckDSSpambotCheckDSSpambotCheckImpl.php): failed to open stream: No such file or directory in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13 Fatal error: require_once(): Failed opening required '/customers/3/5/0/mysite.comhttpd.wwwDSpluginsDSuserDSspambotcheckDSSpambotCheckDSSpambotCheckImpl.php' (include_path='.:/usr/share/php') in /customers/3/5/0/mysite.comhttpd.www/plugins/user/spambotcheck/spambotcheck.php on line 13
8 years 8 months ago #5302 by Administrator AV
Replied by Administrator AV on topic Not compatible with PHP v7.1
which version of the plugin have you installed on your website?
The problems which you report do not match with the code of the latest version 1.3.13 of the extension.
  • Topic Author
8 years 8 months ago #5307 by cd5aac5f206d1be91cada9f7
Replied by cd5aac5f206d1be91cada9f7 on topic Not compatible with PHP v7.1
Dear,
It got fixed installing the latest version of the plugin. I assumed the site was already using the latest version since I checked plugin updates via the Joomla admin console.
But for some reason it did not detect I was using an outdated version.
