Not Showing in Plugins
10 years 5 months ago #3128 by NeilT
Not Showing in Plugins was created by NeilT
I am trying to stop some domains registering to my web site (Kunena Forum)
I have installed this plug in, and from the drop down Component Menu I have options, but these are limited.
But from the actual Joomla Plugin area, the Spambotcheck does not show, so unable to find any way to admin the plug in.
I want to stop domains like:
@getslim.top
infoi@pumpe3.e90.biz
From being able to even register.
Hope someone can help with this, and thank you for reading.
10 years 5 months ago #3130 by Administrator AV
Replied by Administrator AV on topic Not Showing in Plugins
it is as user plugin.
In the administration panel of your website got to extension->plugins.
Then use the Search Tools. In the "Select Type" Dropdown select "user".
You should see the Plugin "User - SpambotCheck" then.
You can only blacklist domains in the format like @getslim.top not full email addresses like in your second example. domains have to start with the @. If you want to blacklist more than one domain, separate them with a comma.
Good luck,
Enter your
The following user(s) said Thank You: NeilT
10 years 4 months ago #3141 by NeilT
Replied by NeilT on topic Not Showing in Plugins
Many thanks for the very quick response, and it was my bad not finding the plugin, but thats all working fine now.
Thanks you.
10 years 4 months ago #3142 by Administrator AV
You're welcome!
