Data Export in excel
10 years 2 weeks ago #3457 by brijesh4534
Data Export in excel was created by brijesh4534
I have a form in my website, now the result is saved in the database. To add those visitors in my CRM system i have to create an excel of the data which i do by exporting the database table from the database and then inserting it into the excel.
Is there a way to do it directly from the visform?????
10 years 2 weeks ago #3460 by Administrator AV
Replied by Administrator AV on topic Data Export in excel
you can create a csv export directly with Visforms.
Use the export button in the "data list view" in the administration.
You can customize the export.
There are options for the export to set in the form configuration (tab advanced) and in the field configuration (tab advanced) of each field.
Take a look at the documentation, section "Exporting saved data"
www.vi-solutions.de/en/documentations/vi...rms/314-save-results
10 years 2 weeks ago #3466 by brijesh4534
Replied by brijesh4534 on topic Data Export in excel
I updated my joomla to 3.6.1 and updated the visforms to 3.8.7 on creating the form when i add title and alias and click on any save button nothing happens, and when i click in the cancel button it gets redirected to visforms main screen.
can you provide me a solution for this.????
10 years 2 weeks ago #3468 by Administrator AV
is this problem specific to Visforms?
Can you create a new Joomla! article and save it or do you have the same problem there.
The following user(s) said Thank You: brijesh4534
10 years 1 week ago #3470 by brijesh4534
yes, there was an sql updation error from extensions--> manage-->database clicked on fix and every thing was solved.
10 years 1 week ago #3471 by Administrator AV
thanks for sharing the solution!
