Enabling better Conditional Field capabilities for complicated scenarios
  • michaelh@notabandoned.org
  • Topic Author
  • Offline
8 years 11 months ago #4797 by michaelh@notabandoned.org
Hi - a feature request suggestion
For example, if you want to list countries and then provinces/states under each where the user sees only the provinces/states of the country selected, there is currently no easy way to do this today. Today I have to create a separate field for each country and their provinces/states. This could be more easily managed through a SQL query if this option was provided. Though there could be other options as well. But this would be very helpful.
