Error 404 in frontend data view sort after update joomla 3.8.4
8 years 1 month ago - 8 years 1 month ago #5206 by Mimmo
Hallo
I receive the error after clicking on a field in the front-end title bar, in order to sort on that field.
You can view the error directly on the page www.transalppuglia.com/vii-orecchietta-tour/partecipanti
Last edit: 8 years 1 month ago by Administrator AV.
8 years 1 month ago - 8 years 1 month ago #5207 by Administrator AV
thanks for this post.
I received a message about a similar problem yesterday but the customer did not relate it to the Joomla! 3.8.4 update and I thought this was an isolated incident. With regards to your post I now assume, that the Joomla! update is not backwards compatible with regards to the sort feature of the search tools and therefore breaks the Visforms data views.
I will take a look into this as soon as possible and will provide an update with a bugfix as soon as possible. Until then, I think you have either to return the backup of your website which you made before the Joomla! update or turn of the table headers, so that the user cannot try to sort the data.
8 years 1 month ago #5208 by Administrator AV
I was able to find a solution for the problem. As creating a release with the bugfix always takes a bit longer, I post the solution here. As far as I can see, there it is only on small code modification that will fix the problem.
Open the file components\com_visforms\views\visformsdata\tmpl\data.php
(make a copy of the file first, just in case something goes wrong and you want to go back to the original)
Replace
<form action="<?php echo JRoute::_('index.php?option=com_visforms&view=visformsdata&layout=data&id=' . $this->id);?>" method="post" name="adminForm" id="<?php echo $this->context; ?>adminForm"><?php
at line 46
with
<form action="<?php echo JRoute::_('index.php?option=com_visforms&view=visformsdata&layout=data&id=' . $this->id. '&Itemid=' . $this->itemid);?>" method="post" name="adminForm" id="<?php echo $this->context; ?>adminForm"><?php
Save your changes.
If you have a Visforms Subscription and use a menu of type "data view with edit link", then you have to fix the file components\com_visforms\views\visformsdata\tmpl\dataeditlist.php, too.
In this file you have to replace the following code at line 66
<form action="<?php echo JRoute::_('index.php?option=com_visforms&view=visformsdata&layout=dataeditlist&id=' . $this->id);?>" method="post" name="adminForm" id="<?php echo $this->context; ?>adminForm"><?php
with
<form action="<?php echo JRoute::_('index.php?option=com_visforms&view=visformsdata&layout=dataeditlist&id=' . $this->id. '&Itemid=' . $this->itemid);?>" method="post" name="adminForm" id="<?php echo $this->context; ?>adminForm"><?php
The following user(s) said Thank You: Mimmo
8 years 1 month ago #5210 by Mimmo
Thanks Aicha,
for the kind, quick and, above all, decisive solution!
8 years 1 month ago #5211 by trf
ich hab das Problem auch nach dem Joomla-Update.
Da ich aber nicht die benannte Datei bearbeiten kann wäre ich dankbar, wenn das bugfix schnell käme.
Vielen Dank.
LG
Jörg
8 years 1 month ago #5212 by Administrator AV
I've just released Visforms 3.10.4 und Visforms Subscription 3.1.2. The only purpose of these releases is, to fix this bug. No other changes or new features are included.
