Error Message
6 years 9 months ago #6426 by van0358tz
Error Message was created by van0358tz
Today I updated site with
vfsubscription_j3.9.0_3.4.5 Beta
visforms_j3.9.0_3.13.7
Now when I open the forms, I get this error line at the very top
Ajax: xxInternal Error Occurred
6 years 9 months ago #6427 by Administrator AV
Replied by Administrator AV on topic Error Message
thanks for this notice.
I think I have to improve the html tagging of this code part a bit.
Actually this message should be hidden by default and this is done with some html classes which are obviously not supported by your template.
The message which contains the "Ajax:: xxInternal Error Occured" as a fix header, should only be displayed if an actual ajax error occurs.
As this problem was reported just 2 days ago by another user, I think, I have to make some modifications to my code.
In the meantime you could try if adding some custom css to your template would help.
Please try the following css.
.visform #ajax-modal-error-dialog.hide {display:none;}
6 years 9 months ago #6437 by van0358tz
Replied by van0358tz on topic Error Message
Dear Aicha,
Thank you for quick responce.
I added The code
to the Editing file "/css/template.css" of my template name: "ygpgpv5".
and saved. I still get the error message.
did I do something wrong?
Thank you
Vangelis
6 years 9 months ago #6438 by Administrator AV
my mistake.
It has to be:
.visforms #ajax-modal-error-dialog.hide {display:none;}
(I missed the "s" at the first selector ".visforms" not ".visform".
Putting that into your template.css should work.
6 years 9 months ago #6439 by van0358tz
It works :) :)
You are fantastic.
Service excellent !!!! Especially with your patience to a novice Joomla site developer like me.
Again, thank you very much !!!!!!!
