form-in-pop-up-window
2 years 8 months ago #10027 by sqs
form-in-pop-up-window was created by sqs
Hello, can the settings in Wisforms enable popup display please? Thank you Milan
2 years 8 months ago #10028 by Administrator IV
Replied by Administrator IV on topic form-in-pop-up-window
Hello Mila,
That's a very manageable question: Visforms itself can't do popups.
The type of window in which the form is displayed is not within the scope of creating the form.
This is the responsibility of the surrounding UI framework and/or additional tools.
This doesn't make much sense in the implementation of a form generator.
Because popups are always generated very differently, depending on which UI framework you use.
Many templates offer out-of-the-box solutions so that you can display the content or the entire module as a popup.
If Visforms then displays the form in this module, you have a solution.
Sometimes popups come as functions of editors or extensions to editors (e.g. the JCE).
But you need such an external functionality to display Visforms in the popup.
Depending on the UI framework, sometimes just the right CSS classes on the form or the appropriate custom JS/CSS are enough.
The UI framework template used then automatically generates the module functions for display as a popup.
Kind regards, Ingmar
