reCaptcha V2 is not validating
1 year 2 weeks ago #11204 by ScoutingAlphen
reCaptcha V2 is not validating was created by ScoutingAlphen
Hello,
I just bought VISforms and started to migrate from Breezing to VIS. I used the migrate tool which seems to work quite well (haven't touched the more challenging forms yet). Now I run into an issue with the Google reCaptcha integration. I have a v3 invisible version and for VISforms I added a V2 checkbox version as well. Both options give me an error on submitting: "The captcha could not be validated" (In Dutch: "De captcha kon niet worden gevalideerd.").
The reCaptcha checkbox is displayed correctly when using the v2 version and the v3 version worked without issues combined with Breezingforms.
What can be the cause of this problem?
V1: Which Visforms version is running? 5.3.1
V2: Which Joomla version is running? 5.2.3
V3: Which PHP version is running? 8.1.29
Best regards,
Jeroen
1 year 2 weeks ago #11216 by Administrator IV
Replied by Administrator IV on topic reCaptcha V2 is not validating
Hello ScoutingAlphen,
Thanks for the version information.
BreezingForms:
We are pleased about your great feedback on the BreezingForms import.
Of course, complex BreezingForms forms have mechanisms that cannot be automatically transferred to Visforms.
But in the case of large forms with many fields, for example, you at least have the form with all the fields after the import.
reCaptcha V2:
Visforms supports reCaptcha V2.
Visforms does not yet support reCaptcha V3 in your current version, which is something completely different.
If you configure reCaptcha V2 correctly in Visforms, it will work.
Simply activating reCaptcha V2 is not enough.
The configuration is simple, but contains two individual access keys from Google for using reCaptcha V2.
The two individual access keys from Google are tied to a domain and are exclusively for using reCaptcha V2.
Background:
reCaptcha V2 in Visforms refers only to the one (1) page on which the form is visible.
reCaptcha V2 has nothing to do with any reCaptcha V3 on your Joomla instance.
reCaptcha V3, on the other hand, refers to the entire Joomla instance with all its contents.
Question 1:
Have you read the documentation for configuring reCaptcha V2?
Google reCAPTCHA V2 boxes:
docs.joomla-5.visforms.vi-solutions.de/d...-dienst-recaptcha-v2
Question 2:
In particular, have you received and entered the two service keys from Google?
Settings in the Visforms configuration:
docs.joomla-5.visforms.vi-solutions.de/d...orms-konfiguration-1
Note:
There are plans to expand Visforms to include reCaptcha V3.
However, reCaptcha V3 is not configured directly in Visforms in the true sense of the word.
In the case of reCaptcha V3, its use simply needs to be activated in the Visforms configuration.
reCaptcha V3 is configured outside of Visforms within Joomla.
There is already an issue for development in the wish list:
Issue [VF-1279] VFJ5: Add Feature: Support of Google ReCaptcha V3 (GRCV3)
Kind regards, Ingmar
1 year 2 weeks ago #11218 by ScoutingAlphen
Replied by ScoutingAlphen on topic reCaptcha V2 is not validating
Dear Ingmar,
I followed all you and the documentation suggested. I have created the keys for Google reCaptcha V2 checkbox. The captcha checkbox is showing on the form but after validating (which also goes without issues), the form shows an error, please use the following link for testing: Test form . The site is in Dutch but the form is simple.
The reCaptcha does work, the validation doesn't, se image below.
With best regards,
Jeroen
Best regards,
Jeroen
1 year 2 weeks ago #11220 by Administrator IV
Hello Jeroen,
Question:
Are you using reCaptcha V3 on your Joomla instance?
Background:
It is very possible that you cannot mix different reCaptcha versions V2/V3 on one page because Google does not allow this.
I don't know for sure though.
Nobody has tried this so far and I would advise against it.
Solving the Captcha:
The form itself is simple.
The text of the instructions that I have to follow is in Dutch.
I was only able to do this after translation.
1 year 2 weeks ago #11223 by Administrator IV
Hello Jeron,
I suspect that you no longer need your own Visforms reCaptcha for Visforms.
Because the invisible reCaptcha V3 is inserted on every page anyway.
In particular on the page with the Visforms form.
There are now a total of 2 integrations on the page with the Visforms form.
The invisible reCaptcha V3:
<script type="text/javascript" async="" charset="utf-8" src="https://www.gstatic.com/recaptcha/releases/rW64dpMGAGrjU7JJQr9xxPl8/recaptcha__nl.js" crossorigin="anonymous" integrity="sha384-ltnwMohzWn9teujtASb4iMj2/Qag/KgxP3iKUrm1JKfdsHqXqCqnEgXWGtRWmZlw"></script>
The reCaptcha V2 from Visforms:
<script src="https://www.google.com/recaptcha/api.js?hl=nl-NL" defer="" async=""></script>
That doesn't make any sense at all.
However you provide the 'invisible reCaptcha V3' on your Joomla instance, an additional reCaptcha V2 through Visforms
- is not necessary,
- does not work.
Best regards, Ingmar
1 year 2 weeks ago #11226 by ScoutingAlphen
Hello Ingmar,
When I change the reCaptcha from the Breezingforms to V2 (the same as the VISforms) everything works like a charme. For the VISforms the error keeps popping up.
Link to the Breezingform
Link to the VISform
I use the exact same keys, have set the default Captcha for Joomla to V2 as well. I don't know what else to do.
Best regards,
Jeroen
Best regards,
Jeroen
