Display number of records
1 year 1 month ago - 1 year 1 month ago #11749 by PFS_hansi
Display number of records was created by PFS_hansi
I want to display the number of records from the form with ID 2 and with fieldID 29 = "My Headline"
How can I do this?
{vfdataview}{"formid":"2","fieldselect":{"29":"My Headline"},"count":"1","displaycounter":"true","sortorder":"created","sortdirection":"desc","show_page_heading":"false","showlabel":"false","layout":"list"}{/vfdataview}
rg
Hansis
Last edit: 1 year 1 month ago by PFS_hansi. Reason: Rechtschreibfehler
1 year 1 month ago #11750 by Administrator AV
Replied by Administrator AV on topic Display number of records
Hi Hansis,
The Data View plugin is used to display the records submitted for a form.
The plugin's configuration allows you to specify which fields the data is displayed for, how many records are displayed on a page, whether search filters are enabled, and similar settings.
The plugin cannot be used to aggregate data content.
For example, it cannot be used to count the number of records.
One way to achieve your desired goal would be:
- Create a new form
- This form has exactly one field of type Listbox SQL (and no submit button)
- Activate the 'Display as Data List' option in this field.
- Write an SQL statement that counts the number of records in the desired form for which the desired field is not empty
- Display this form using the Form View plugin in the same location where you are currently using the Data View plugin.
The following user(s) said Thank You: PFS_hansi
