Submit button not visible
9 years 4 months ago #3783 by Guiguy
Submit button not visible was created by Guiguy
Nice component. Generally well done.
However, the submit button is not visible on our white background template. It only becomes visible on our CSS button class when the mouse cursor moves over it.
Where can I fix it? If it is in one of the visform css files, which one and what is the class name?
Thanks
9 years 4 months ago #3784 by Administrator AV
Replied by Administrator AV on topic Submit button not visible
Thank you,
in order to fit into the look and feel of your template, Visforms comes with week css selecors, so that usually the css of your template is used. As far as I remember, there is no css rule for the submit button in the visforms css.
As there are different form layouts available in Visforms, which have different html structure, I cannot tell you exactly which selector you can use to style the submit button in your form but I wrote an article in the documentation ( www.vi-solutions.de/en/documentations/vi...form-layout-with-css ) where I explained, how you can find out.
In addition, it is possible to add a custom class attribute to the field (in field configuration tab advanced) which you could use in your css.
9 years 1 month ago - 9 years 1 month ago #3898 by Guiguy
Replied by Guiguy on topic Submit button not visible
I gave up previously because I just was not able to do anything to get the button to be visible. No editing of CSS classes or applying classes worked. So I gave up a couple of months ago.
I'm now back trying to use what is otherwise an excellent extension. This time there is a darker btemplate and I see the button is not visible again. I now realise it is transparent!!??
I have tried different templates, the result is always the same. The buttons on the form including the captions are transparent. None of my efforts of trying to apply a different class have worked, so I am clearly doing something wrong.
What is the fix?
Thanks
Last edit: 9 years 1 month ago by Guiguy.
9 years 1 month ago #3899 by Guiguy
Replied by Guiguy on topic SOLVED: Submit button not visible
Nevermind. Tripped, went arse over tit and my nose hit the solution.
"Advanced" > "CSS Class For Field" does not work with my main template classes other than for hover.
However, I found applying btn-save from visforms.css sort of worked. It's not the prettiest but it will do.
Thanks
