Visforms validation error
9 years 2 weeks ago #4163 by f.fraczek
Visforms validation error was created by f.fraczek
Hello,
since today I'm facing a jquery validation problem on my site. When I open a layer where my form is I see this code breaking the site:
', url: 'Please enter a valid url:
E.g. www.domain.com ', date: 'Please enter a valid date.', dateISO: "Please enter a valid date (ISO).", number: 'Please enter a valid number.', digits: 'Please enter a digit.', creditcard: "Please enter a valid credit card number.", equalTo: 'Please repeat the value.', maxlength: jQuery.validator.format('Please enter no more than {0} characters.'), minlength: jQuery.validator.format('Please enter at least {0} characters.'), rangelength: jQuery.validator.format('Please enter {0} to {1} character.'), range: jQuery.validator.format('Please enter a number between {0} and {1}.'), max: jQuery.validator.format('Please enter a number lower or equal {0}.'), min: jQuery.validator.format('Please enter a number greater or equal {0}.') }); jQuery.validator.addMethod("dateDMY", function(value, element) { var check = false; var re = /^(0[1-9]|[12][0-9]|3[01])[\.](0[1-9]|1[012])[\.]\d{4}$/; if( re.test(value)) { var adata = value.split('.'); var day = parseInt(adata[0],10); var month = parseInt(adata[1],10); var year = parseInt(adata[2],10); if (day == 31 && (month == 4 || month == 6 || month == 9 || month == 11)) { check = false; // 31st of a month with 30 days } else if (day >= 30 && month == 2) { check = false; // February 30th or 31st } else if (month == 2 && day == 29 && ! (year % 4 == 0 && (year % 100 != 0 || year % 400 == 0))) { check = false; // February 29th outside a leap year } else { check = true; // Valid date } } return this.optional(element) || check; }, "Please enter a valid date."); jQuery.validator.addMethod("dateMDY", function(value, element) { var check = false; var re = /^(0[1-9]|1[012])[\/](0[1-9]|[12][0-9]|3[01])[\/]\d{4}$/; if( re.test(value)) { var adata = value.split('/'); var month = parseInt(adata[0],10); var day = parseInt(adata[1],10); var year = parseInt(adata[2],10); if (day == 31 && (month == 4 || month == 6 || month == 9 || month == 11)) { check = false; // 31st of a month with 30 days } else if (day >= 30 && month == 2) { check = false; // February 30th or 31st } else if (month == 2 && day == 29 && ! (year % 4 == 0 && (year % 100 != 0 || year % 400 == 0))) { check = false; // February 29th outside a leap year } else { check = true; // Valid date } } return this.optional(element) || check; }, "Please enter a valid date."); jQuery.validator.addMethod("dateYMD", function(value, element) { var check = false; var re = /^\d{4}[\-](0[1-9]|1[012])[\-](0[1-9]|[12][0-9]|3[01])$/; if( re.test(value)) { var adata = value.split('-'); var year = parseInt(adata[0],10); var month = parseInt(adata[1],10); var day = parseInt(adata[2],10); if (day == 31 && (month == 4 || month == 6 || month == 9 || month == 11)) { check = false; // 31st of a month with 30 days } else if (day >= 30 && month == 2) { check = false; // February 30th or 31st } else if (month == 2 && day == 29 && ! (year % 4 == 0 && (year % 100 != 0 || year % 400 == 0))) { check = false; // February 29th outside a leap year } else { check = true; // Valid date } } return this.optional(element) || check; }, "Please enter a valid date."); jQuery('.captcharefresh3').bind({ 'click' : function() { if (jQuery('#captchacode3')) { jQuery('#captchacode3').attr('src', 'index.php?option=com_visforms&task=visforms.captcha&sid=' + Math.random()+ '&id=3'); } } }); }); jQuery(document).ready( function(){ jQuery(document).displayChanger(); jQuery(".conditional").on("checkConditionalState", {restricts : {}}, function (e) { jQuery(this).toggleDisplay(e.data.restricts); }); }); //fix placeholder for IE7 and IE8 jQuery(document).ready( function () { if (!jQuery.support.placeholder) { jQuery("[placeholder]").focus(function () { if (jQuery(this).val() == jQuery(this).attr("placeholder")) jQuery(this).val(""); }).blur(function () { if (jQuery(this).val() == "") jQuery(this).val(jQuery(this).attr("placeholder")); }).blur(); jQuery("[placeholder]").parents("form").submit(function () { jQuery(this).find('[placeholder]').each(function() { if (jQuery(this).val() == jQuery(this).attr("placeholder")) { jQuery(this).val(""); } }); }); } });
You don't have to fill the form at all, It's just there when you relod the page.
Can anyone help me with fixing that?
9 years 2 weeks ago #4164 by Administrator AV
Replied by Administrator AV on topic Visforms validation error
this certainly did not just happen without any reason or any changes you made.
I think, that this may be due to an invalid quote or double quote but I do not know where exactly it comes from.
Did you update Visforms?
Did you modifiy your forms or fields? I.E. create/modify texts in form or field configuration, create/modify option lists of selects/radios/checkboxgroups or anything like that, where you used quotes or double quotes
Did you modify language files or installed new language files
Could I have a link to take a look at the form?
The following user(s) said Thank You: f.fraczek
9 years 2 weeks ago #4165 by f.fraczek
Replied by f.fraczek on topic Visforms validation error
Hi, thanks a lot for a quick reply.
Here's a link to a site where one of visform forms is used - just click on the purple button - elliteq.pl/jednolity-plik-kontrolny
In terms of module update i believe I have the newest versions as I update all my plugins and modules/
An yes, I did make some enhancements in form, but it was nothing major and I did not add any quotes.
I really appreciate your help.
9 years 2 weeks ago #4166 by f.fraczek
Oh! It wasn't updated after all. I just believed in auto updates.
It works fine now. Thanks a lot!
9 years 2 weeks ago #4167 by Administrator AV
Well, fine then.
