How create a view data form
8 years 9 months ago #4464 by emi65
How create a view data form was created by emi65
Hi
I'm able to create a form where collect data from the web visitor
But I didn't understand how create a form to view these data
Do I need a payable Visform version ?
Thanks
Emilio
8 years 9 months ago #4467 by Administrator AV
Replied by Administrator AV on topic How create a view data form
there is a menu item of type Visforms >> Formadata in the free Visforms version which you can use to display collected data in the front end.
You can follow the instructions in the documentation article www.vi-solutions.de/en/documentations/vi...rms/314-save-results in order to set this up.
Basically you have to make sure that the option "Save Results" is enabled for the form. Than you go to the tab "Dataview in Frontend" in the form configuration where you have to "Allow Frontend Data View" and where you can make some more configuration settings for this view. Then you have to enable/allow for each field, which you want to display in the data view, that it can be displayed in the data view (Field Configuration, tab "Advanced").
8 years 9 months ago #4471 by emi65
Replied by emi65 on topic How create a view data form
Thanks for the Help
I did an error about Joomla Menu definition
I Joined the Menu to Form
I modified to Formdata and now I'm able to show the stored data
Is there a way to have input field and show stored data on the same page ?
8 years 9 months ago #4473 by Administrator AV
do you mean that you want to show the form and the data on the same page?
You would need to display the form in a module then (create a module of type Visforms) and display that module on the page that displayes the Visforms data menu item.
8 years 9 months ago #4475 by emi65
I didn't understand
1) I create a module to input the data using visform OK ... I undestand
2) I show this module in a page ... how can I do it ? (just using the plugin ???)
thanks
emilio
8 years 9 months ago #4476 by Administrator AV
Publishing a module has nothing to do with Visforms and you do not need a Visforms Subscription in order to display the module Visforms.
The positions where you can display a module on your website are controlled by your template. You have to choose a position for the module, that is supported by your template and which shows up in your template at a "place" where you like to display your form.
