SQL read only field
  • michaelh@notabandoned.org
  • Topic Author
  • Offline
8 years 5 months ago #4795 by michaelh@notabandoned.org
SQL read only field was created by michaelh@notabandoned.org
Hi - this is likely a feature request.
You have a powerful solution for managing forms. What is missing is the ability to generate a new data point from the form submission (such as calculating current age from a birth date) and then adding this field to the record as read only. I can create this using MySQL queries but being able to show this on the form would require a new field type where SQL queries could be used.
