Accordion not displaying well
8 years 4 months ago #4858 by erichayes
Accordion not displaying well was created by erichayes
Please see erichay.es/boehle/products-visform .
Resins and Pigments are pagebreaks. I want Resins and Pigments to be collapsed by default and click to expand. Thanks.
8 years 4 months ago #4862 by Administrator AV
Replied by Administrator AV on topic Accordion not displaying well
obviously there is some CSS missing. I will take a look into this on Monday. At the moment I think it can be fixed easily.
8 years 4 months ago - 8 years 4 months ago #4863 by Administrator AV
thanks for your patience.
I have added some CSS to the Visforms CSS.
Basically it is the default Boostrap CSS code for accordions/collapsables.
As far as I can see this fixes the problem.
I will send you the modified file, so that you can test with it.
Please let me know if this fixes the problem.
Please note, that the default behavior of bootstrap accordions is, that the first panel is expanded by default, when the page is displayed. The other panels are collapsed.
As Visforms uses the default bootstrap accordion HTML, Javascript and CSS, at the moment there is no way to display the first panel collapsed but I will set that as a feature request to my feature reqeust list.
I have added the following CSS code to the media\com_visforms\css\visforms.min.css
/*Accordions*/ .collapse { position: relative; height: 0; overflow: hidden; -webkit-transition: height 0.35s ease; -moz-transition: height 0.35s ease; -o-transition: height 0.35s ease; transition: height 0.35s ease; } .collapse.in { height: auto; } .accordion { margin-bottom: 20px; } .accordion-group { margin-bottom: 2px; border: 1px solid #e5e5e5; -webkit-border-radius: 4px; -moz-border-radius: 4px; border-radius: 4px; } .accordion-heading { border-bottom: 0; } .accordion-heading .accordion-toggle { display: block; padding: 8px 15px; } .accordion-toggle { cursor: pointer; } .accordion-inner { padding: 9px 15px; border-top: 1px solid #e5e5e5; }
Last edit: 8 years 4 months ago by Administrator AV.
8 years 4 months ago #4870 by erichayes
Replied by erichayes on topic Accordion not displaying well
Yes, that fixed the issue. Thank you very much.
8 years 4 months ago #4871 by Administrator AV
You're welcome.
And thanks for your response. Now I can merge the changes into the Visforms code, and permanently fix the problem.
With the next Subscription release there will also be a new option, where you can choose, whether to display the first panel expanded or collapsed.
