Changing order of fields
13 years 3 months ago #139 by xtime123
Changing order of fields was created by xtime123
Hello;
I am adding two new questions to an existing form, but see no way to order the questions. Do I have to recreate all the questions every time I want to add a new one or is there a way to change the order that I'm not seeing?
I don't have the form assigned to a menu, I'm using it in a module on all pages - Joomla 2.5.
Thanks!
Dave R
13 years 3 months ago #140 by Administrator AV
Replied by Administrator AV on topic Re:Changing order of fields
Hi Dave,
you should be able to order the questions (fields). It works just like ordering in Joomla! 2.5 works.
You have to click on the label "Order By" in the header of the field-table. Thereafter you can change the order. You will see those blue-white arrows to move a field one position up or down. The input-fields with the order number in this table should be editiable to, after you have clicked on "Order By". You can use this input for changing the order as well.
After you are done, click on the save symbol in the table header (at the right side of the text "Order By").
Regards, Aicha
13 years 3 months ago #142 by xtime123
Replied by xtime123 on topic Re:Changing order of fields
I tried that and it didn't work, but now it does! I must have clicked the wrong thing the first time.
Sorry to waste your time, and thanks for the quick response!
Dave
13 years 3 months ago #143 by Administrator AV
Hi Dave,
no problem. Your wellcome.
Kind Regards,
