visforms for registration
8 years 2 months ago #5129 by standalonec
visforms for registration was created by standalonec
I would like to use visforms to replace the registration from joomla and I have some problems.
1. How the link the data to user database in joomla
2. The form is about different user groups need to fill in different content, how can I link the user groups i created to select type and
3. How can i change the form contents dynamically when I selected different user group
4. where can i find/create activation email after registration like joomla its own registration. Besdies, I would like to one group using activation email to confirm and another using admin for activation but i don't know how to separate.
Please help, thanks a lot!
8 years 2 months ago #5130 by Administrator AV
Replied by Administrator AV on topic visforms for registration
you cannot use visforms to replace the Joomla! registration. So this is just not possible.
Although Joomla! registration (like any registration) has a form, the Joomla! registration is a user component and not a form component.
The aim of Visforms is completely different. It is a form component that allows you to create very flexible custom forms but it does not interact with the Jooomla! user registration.
The following user(s) said Thank You: standalonec
8 years 2 months ago #5131 by standalonec
Replied by standalonec on topic visforms for registration
Thanks for your quick reply, So do you have any suggestion for the situation I mentioned?
8 years 2 months ago #5132 by Administrator AV
Sorry but no.
