Entering CSS class
13 years 3 months ago #159 by Frank
Entering CSS class was created by Frank
I would like to add some css to a text name field but am notsure how to do it. I see there is a layout tab for the field and I can put a CSS class selector in there but what else must I do to make this selector active. :)
The topic has been locked.
13 years 3 months ago #160 by Administrator AV
Replied by Administrator AV on topic Re:Entering CSS class
Hi Frank,
first you type the classname you want to put to the field (or the label) into the respective field parameter (CSS class for label or CSS class for field). I advise to put a blank (character) in front of the classname because that allows you to use that classname separately.
Next you have to write some css code either in the visforms css file or a css file of your template. For example if you typed in " myClass" in the field configuration. You can add custom css by adding
.myClass {add your css rules here}
in a css file.
You can edit the visforms css files from your Joomla Backend. In the forms view there is a button "edit css".
Add your custom css at the bottom of that file so that it will override previous rules for the field.
Good luck and kind regards,
13 years 3 months ago #161 by Frank
Replied by Frank on topic Re:Entering CSS class
Thanks for the help Aicha.
I got it to work by adding my class to the visforms.css file. I need to get it working in an "override" file now.
Regards - Frank
13 years 3 months ago - 13 years 3 months ago #162 by Administrator AV
Hi Frank,
it would be helpful, if I could take a look at the form.
Could you please post the link (or send it to my e-mail which you find bellow in the page's footer module) ?
And the field you put the css class to.
Kind Regards,
Last edit: 13 years 3 months ago by Administrator AV.
13 years 3 months ago #163 by Frank
Hi Aicha,
Your advice to use firebug was right on the mark. With it I was able to solve the problems I was having. Firebug is one great tool.
Many thanks !.
Regards - Frank
13 years 3 weeks ago - 13 years 3 weeks ago #257 by Joeyb
Replied by Joeyb on topic Re:Entering CSS class
Hey,
I'm having trouble with the css file. I want to change the size of the textboxes, only i don't know how. PLEASE help me! The only thing i need to know is, how i increase the width and decrease the hight.
if you could help me I would appreciate it.
Joey b.
Last edit: 13 years 3 weeks ago by Joeyb.
