recaptcha problem
7 years 2 months ago #5948 by vmurphy
recaptcha problem was created by vmurphy
I'm trying to add a captcha to an existing form ( www.drhowellelectric.com/contact ). I've enabled and setup the joomla recaptcha plugin. When I enable recaptcha (or visform captcha), I get an error on the page (Error while rendering position). I've attached a screenshot. I've had to turn the captcha off for now. Wondering if you've seen anything like this before. Thanks.
Cheers...Vince
7 years 2 months ago #5949 by Administrator AV
Replied by Administrator AV on topic recaptcha problem
If you have enabled the invisible recaptcha on your website and you try to use a captcha with the form, this is not working and you will have errors. If have not had any time jet to look into this problem in more detail. Basically it is caused by the fact, that the invisible recaptcha plugin has a very similiar html code as the recaptcha plugin, but works differently.
If you have only enabled the recaptcha plugin and select the recaptcha or the Visforms Captcha in the form, this should actually work fine.
By the way, Visforms already has very good protection against spambots, even without any captcha, because auf the visforms plugin spambotcheck. So usuallly it is not really necessary to enable any captchas for the forms. (See: www.vi-solutions.de/en/documentations/vi...t-forms-against-spam )
7 years 2 months ago #5951 by vmurphy
Replied by vmurphy on topic recaptcha problem
Thanks for the quick reply. I did have the invisible captcha plugin enabled so I disabled. I now only have the recaptcha plugin enabled but I still get the error using either a setting recaptcha or visform. Any other thoughts?
Cheers....Vince
7 years 2 months ago #5952 by Administrator AV
Hi, attaching a screenshot did not work in your first post. Can you send me the screenshot to contact@vi-solutions.de
Regards Aicha
7 years 2 months ago #5953 by vmurphy
Thanks, email sent.
7 years 2 months ago #5954 by Administrator AV
thanks.
You have created overrides for the mod_visforms layout files in your template.
These overrides are based on an older version of the visforms layout files.
There were important changes to the layout files between visforms 3.11 and 3.12.
So you have to rebuild the overrides based on the current layout files of the mod_visforms.
This will fix the problem.
