Data view plugin trouble
7 years 1 month ago #6127 by smpSami
Data view plugin trouble was created by smpSami
Hello,
I'm have two problems with plugin data view (in an article). First is the detail view icon. I can't get it to show. It only shows the id number as a link. The second problem is that the maxtextwidth parameter does nothing. In frontend view there is no problem
This is the code script i have:
{vfdataview}{"formid":"7","fieldlist":"117,118,121","sortorder":"117","sortdirection":"desc","display_num":"5","show_page_heading":"false","displaydetail":"true","viewclass":"jlist-table","displayid":"false","maxtextlength":"200","displaycounter":"true","fieldselect":{"114":"testikohde"}}{/vfdataview}
This is what it looks like in frontend view and what I would want it to look like in content plugin data view:
And this is what it looks like now:
7 years 1 month ago #6128 by Administrator AV
Replied by Administrator AV on topic Data view plugin trouble
I will try to set up a test environment and check, if I can reproduce the problem.
7 years 1 month ago #6129 by Administrator AV
ok. I think you actually found two things that do not work as they should. Sorry for that. I will provide bugfixes with the next Visforms/Subscription release.
If you want to, you can try to apply the fixes right now.
1. Textlength is does not work.
Open the file plugins\content\vfdataview\tmpl\default.php
Replace the code at line 102
echo $texte = JLayoutHelper::render('visforms.datas.fields', array('form' => $this->form, 'field' => $rowField, 'data' => $row, 'text' => $texte, 'htmlTag' => $this->valueHtmlTag, 'class' => $this->valueClass . ' data-f' . $rowField->id, 'extension' => $this->extension, 'view' => 'list', 'makeLocationUnique' => true, 'viewType' => $this->viewType), null, array('component' => 'com_visforms'));
with the following code
echo $texte = JLayoutHelper::render('visforms.datas.fields', array('form' => $this->form, 'field' => $rowField, 'data' => $row, 'text' => $texte, 'htmlTag' => $this->valueHtmlTag, 'class' => $this->valueClass . ' data-f' . $rowField->id, 'extension' => $this->extension, 'view' => 'list', 'makeLocationUnique' => true, 'viewType' => $this->viewType, 'pparams' => $this->pparams), null, array('component' => 'com_visforms'));
2. Icon not showing up
Open the file components\com_visforms\models\visformsdata.php
Replace the code at line 562
$form->$plgParamName = (($form->$parameter == "1" || $form->$parameter == "2" || $form->$parameter == "3")) ? true : false;
With the following code
$form->$plgParamName = ($this->pparams[$parameter] == "true" && ($form->$parameter == "1" || $form->$parameter == "2" || $form->$parameter == "3")) ? true : false;
Or for this 2. Problem, as a workaround, you could just set the form option "Display Id" to "don't" show. But this will, of course effect other data views for that form as well.
Please don'f forget to make a copy of the files, before you make changes, just in case....
The following user(s) said Thank You: smpSami
7 years 1 month ago #6130 by smpSami
Replied by smpSami on topic Data view plugin trouble
Hello!
Both fixes worked well! Thank you!
7 years 1 month ago #6131 by Administrator AV
thanks a lot for letting me know that they work!
Kind Regards,
