#500 JHtmlVisforms::getCaptchaHtml not found.
6 years 5 months ago #6339 by Stefano
hi Aicha,
I'm try to upgrade a Joomla 3.8.8 to the last one, all goes fine, Jooma update correctly, Visforms Version 3.10.4 update correctly, but at the end all the pages (url) of the site returned a 404 error, only the home and categories view works correctly.
The only "warning" was that the subscription of Visform was ended, ok ;-) I asked to my costumer for renovation, but is there any explanation or fix of this error (that is annoyng, becouse require me to reset all the web site by a backup :-( )
have a nice day
Stefano
6 years 5 months ago #6341 by Administrator AV
Replied by Administrator AV on topic #500 JHtmlVisforms::getCaptchaHtml not found.
Hi Stefano,
each visForms Version has a matching subscription version. (Mostly a subscription matches a range of visForms versions) but if have updated visForms 3.10.4 to a higher version you must probably update the visForms Subscription, too. As you have a visForms Subscription - unlimited, there is no restriction to get visForms Subscription updates for you.
Updateing the subscription to the correct version should fix the problem.
