Using JCE instead of TinyMCE
5 years 3 weeks ago #7272 by djmelville
Using JCE instead of TinyMCE was created by djmelville
Is there a way to change the default editor in Visforms back-end component to use my system-defailt editor JCE instead of the primative TinyMCE?  Thank you.
5 years 3 weeks ago #7274 by Administrator AV
Replied by Administrator AV on topic Using JCE instead of TinyMCE
no there is not, because the JCE does not support multiple instances of the editor in one administrator form properly.
It would not possible to use the Editor-Plugins like the button which is used to insert Visforms Placeholder into the texts.
