Need current documentation
5 years 15 hours ago - 5 years 15 hours ago #7330 by sjb1963
Need current documentation was created by sjb1963
Trying to make a SIMPLE multi column form.
Gone all through the doc. Nothing.
www.vi-solutions.de/en/documentations/vi...0-multi-column-forms
Tried EVERY combination of bootstrap and the multiple ineffective formats they are supposed to provide.
Seldom have I ever paid as much for this level of frustration.
BASIC STUFF HERE
Last edit: 5 years 15 hours ago by sjb1963.
4 years 11 months ago #7333 by Administrator AV
Replied by Administrator AV on topic Need current documentation
Which Joomla! template do you use on your website?
4 years 11 months ago #7338 by sjb1963
Replied by sjb1963 on topic Need current documentation
The framework is Helix Ultimate (1.1.2 - latest)
I also use sp-pagebuilder from the same people. (again, latest)
I build my own templates based on these.
I'm pretty conscientious about not hacking the core, so aside from aesthetic considerations, I don't usually do new overrides or a lot of custom coding.
Thank you for your reply.
4 years 11 months ago #7341 by Administrator AV
Visforms supports the display of several common template frameworks (Bootstrap 2 to 4, UIkit 2 and 3).
The framework-independent ‘Default Layout’ is pre-selected for each form.
It must be set to the active template framework under the setting ‘Form layout’.
As far as I can learn from the Helix Ultimate product page it is build with Bootstrap 4.
If that is the case, you would have to select the "Bootstrap 4" layout in the form layout configuration (form configuration: Tab "Advanced").
How a multi column form is set up, depends on the selected form layout (and how the underlying layout framework is build).
Therefore there are multiple articles in our documentation explaining how to set up a multi column form, depending on the selected form layout.
For the Bootstrap 4 layout the instructions are here: www.vi-solutions.de/en/documentations/do...-bootstrap-4-layouts
If the Helix Ultimate framework uses another layout framework (i.e. Bootstrap 3), then please have a look at this documentation article first:
www.vi-solutions.de/en/documentations/vi...layout-configuration
By the way, I actually think, Helix is a great template framework.
4 years 11 months ago #7342 by sjb1963
Ok, apparently I did not drill down far enough after selecting bootstrap 4. This looks like it opens things up considerably.
I agree. I think Helix is a really good framework. Used for several years now.
