Layout question
12 years 11 months ago #198 by arpeggio
Layout question was created by arpeggio
Hello.
Thank you for your work in porting CK forms. I noticed that the field labels display above the input in the VIS forms and in CK forms they would display to the left of the input. How do I change it to display left of the input?
Best Regards,
Rich
12 years 11 months ago #199 by Administrator AV
Replied by Administrator AV on topic Re:Layout question
Hi Rich,
labels should be left of the input with one exception. If the input is a textarea the label is above.
So, if the label is above the input for all fields, most probably somethings went wrong with your installation and the css-file is not installed correctly. Did you recieve an error message on installing visForms? It would be helpful to have a look at the form. Could you post (or send at the e-mail in the footer) a link to the form?
If it's only the label for textareas and you want to change this please let me know. I will have a look at it then.
