Submit and redirect
4 years 2 months ago #7804 by java
Submit and redirect was created by java
Good evening,
How can I redirect frontend users to the form on submission?
Greetings,
4 years 2 months ago #7808 by Administrator AV
Replied by Administrator AV on topic Submit and redirect
Hi java,
you have to set the parameter 'Redirect URL' in the form configuration on the second tab named 'Result'.
There are choices on how to specify the URL:
1. If there is a menu (which is the best and secure way):
A: only the relative internal menu URL like: index.php?Itemid=[menü-item-id]
where [menü-item-id] stands for the menu item ID
B: the complete SEO URL of the menu like: www.server.com/index.php/listbox
2. If there is no menu or else:
only the relative internal form URL like: index.php?option=com_visforms&view=visforms&id=[form-id]
where [form-id] stands for the form ID
Any other internal/external URL is also possible.
Best regards, Ingmar
